ecu for b18c in 98 civic
my emissions is coming up in a few months, i have a b18c1 in a 98 ex. ive been running it on a s300 with a stepdown harness, what computer do i need to get to pass?
Re: ecu for b18c in 98 civic
thanks, so im thinkin an obd2a p72 should do the trick? or an obd2b em1 p2t with 2a-2b conversion harness? also motor has jdm oil pump so i have to do the ckf wiring trick
alright thanks again, i was wonderin about the si ecu because ive heard the acura ecus have a built in immobilizer and you have to bring the car down to a dealership to have em sync it or somethin along those lines to get it to work in another car
ah ok thanks for clearin that up, nope not jdm its a c1 but has jdm oil pump, the head and the block is also slightly built (jdm itr P+R,S2pro1cams, supertech springs+T retainers), its pretty mild build so i figured the ecu should be able to make it work with no cel
