92 civic hatch h2b -17 degrees timing
just as tittle says. aem reads -17 degrees of timing when i try to crank when dizzy is hot and it stays at -17 degrees. doesn't jump or vary. oem dizzy by the way. cold i get 16 degrees of timing and it starts fine. at -17 i get intake backfire. weezing no start. what part in the dizzy tells the ecu the degrees of timing. icm coil. the cam and crank sensors in the dizzy??
Re: 92 civic hatch h2b -17 degrees timing
have you tried to rotate the distributor to retard it one degree? i really don't think one degree would keep it from firing up. have you checked mechanical timing?
allnaturalb16
21
08-14-2007 08:57 PM
