Please help!!! Engine flooding!!
Old Jan 21, 2015 | 08:32 AM
Adamrives's Avatar
Default Please help!!! Engine flooding!!
I'm new to the whole forum thing so if this is the wrong place to put this I'm sorry. I have a 2000 civic si ls-vtec swap. It's a b18b1 with a gsr head and t3/t4 set up. I'm not sure on the ecu everything was done to the car when I got it. Well my problem started when I burned a hole in the number 3 piston. I had a spare b18b1 I swapped a piston out of. I then reinstalled everything. When I went to fire it up it wouldn't run unless you gave it some gas. It was running super rich. If I gave it some gas it would run but sounded like it was cammed. I retimed the motor 4 times and it still does it. The plugs are soaked with fuel. Fuel pressure is around 32 at idle. If you need more info please ask and I'll try to help. I'm lost I am new to boosted vehicles and it is the first Honda I have pulled down so any help is appreciated.
Old Jan 24, 2015 | 11:56 AM
Adamrives's Avatar
Default Re: Please help!!! Engine flooding!!
Anyone?
Old Jan 24, 2015 | 09:15 PM
Dadragonlord289's Avatar
Clean The Spark Plugs and make sure their dry, then when you go to turn on the car, leave it in accessory, hold down the gas for 5 to 10 seconds then turn it on
Old Jan 24, 2015 | 11:22 PM
kingofbattle909's Avatar
What kinda plugs?
part#?..
Old Jan 25, 2015 | 04:25 AM
Adamrives's Avatar
I don't remember the part number they are ngk's and thanks guys I'll try that tomorrow I am working a 12 hour shift today. What would make it do this? Thank you guys for all the help!
Old Jan 25, 2015 | 06:19 PM
Adamrives's Avatar
OK that cleaned it out and aloud it to crank. However when it cranked it flooded again. It only ran for about 2 seconds. And when it was running it was idling rough
Old Jan 27, 2015 | 07:59 AM
Adamrives's Avatar
Still no luck any help is appreciated.
Old Jan 28, 2015 | 03:28 PM
LTCxD2B's Avatar
Check ur injectors they may be stuck open since the fuel pressure should be around 45 at idle
Old Jan 29, 2015 | 02:16 AM
Adamrives's Avatar
Can you tell me the best way to do this? And is it possible for all 4 to be stuck open? I checked the pig tails with a noid light and they are pulsing.
Old Jan 29, 2015 | 04:32 AM
LTCxD2B's Avatar
Just put a screw driver or something solid to the injector and listen for a pulse or click of the injector opening.. The noid light will only tell u if its getting power
Also figure out the tune ... U may be in some form of limp mode ... Check for codes
Old Jan 29, 2015 | 04:48 AM
Adamrives's Avatar
I'm working 7-12s right now but when I get a chance I'll try that. Thanks a lot I'll let you know what I find out.
Old Jan 30, 2015 | 04:25 PM
Adamrives's Avatar
Injectors are pulsing and it won't Scan for any codes. I scanned it for obd2 is it possible I have a obd1 ecu?
Old Feb 2, 2015 | 10:17 AM
LTCxD2B's Avatar
Yea if it's has any type of chip in it... It's obd1 since that's the only type of Ecu u can chip for b series ... Use the jump trick on the connector above the Ecu area and start counting flashes ... That's assuming ur check engine light works at all
Old Feb 2, 2015 | 11:47 AM
Adamrives's Avatar
Ok thank you I will try this out and let you know what I find out. �� thank you.
Old Feb 7, 2015 | 12:12 PM
Adamrives's Avatar
Ok I only got 1 code it was 21. Which is vtec syloniod correct?
Old Feb 9, 2015 | 11:03 AM
LTCxD2B's Avatar
Yea ... Well I guess it's time to look into ur tune man ... Mechanically if everything is correct it's the tune
Old Feb 9, 2015 | 01:51 PM
Adamrives's Avatar
So that won't cause this to happen? Damn lol that's not what I wanted to hear lol well I guess I'll be headed to the turner soon
Old Feb 10, 2015 | 01:31 PM
Adamrives's Avatar
So turns out I have hondata s300. Does anyone know if I can send them my ecu to see if it's messed up?
Old Feb 10, 2015 | 02:50 PM
LTCxD2B's Avatar
Try the trouble shoots from the website help
hawjboi
17
Nov 11, 2008 08:56 AM
aziantegger10
Apr 8, 2005 03:05 PM
social_control
Aug 31, 2003 10:25 AM
