What axles do I use?
Hey there ht
So I got an h23a1 swap for my 00 Civic
And I finally finished everything else except the axels
I'm just not sure of what axles that I can use
Any info or help?
Thank you guys in advance 👍✌
Any info or help?
Re: What axels do I use
A quick search and reference HondaTech in it will get you your answer quicker than posting on here 99% of the time.
https://honda-tech.com/hybrid-engine...mation-434668/
Do you have the ability to build your own axles or are you trying to purchase some "ready made" ??? We can help you either way, but we need additional information from you to properly direct you. Two people have asked you for information above me and you did not reply... instead, you went and created a second post in "URGENT CAPS". If you truly would like some help, I suggest you delete the other post and then come back here and answer the following:
What transmission are you using ???
What brand of mount kit are you using ???
Does your intermediate shaft have a female socket or male spline on the driver's side end ???
How LOW is your car ???
Yeah i did post another thing but it was right after this and it took forever to post so I didn't think it actually got submitted
I do apologize about that
And I'm using the regular h23 tranny m2f4?
If I read it right
And the mounts I'm not sure they're red and black but don't say anything on them
And my car is lowered just 1 1/2 inches to 2 the most
And when I got the swap it came with axles that were completely destroyed so I can't figure out which ones they are it has everything as far as axles just really messed up you know?
And I was planning on just buying some ready made if that's possible
If I read it right
