h2b crx traction bar troubles !!!###
Keyboard Humorist
Re: h2b crx traction bar troubles !!!###
If Bently Coop's solution doesn't help fix your problem then you should probably try pushing the car off a cliff. Seems to help all the people that have similar problems to yours.
Well im doing this h2b swap and the innovative traction bar is weird cause they say i have to put the radius rod on the bottom i dont understand what they mean by that and my rex will not go off a cliff
Steve at Heart
If your first post would have half the information as second I could have easily provuded a answer. See the thread below for possible solution. Also check out whitfield mfg, they have spacers available. Might be what you're after.
https://honda-tech.com/hybrid-engine...ulley-3225482/
JDM_home
01-19-2015 06:43 AM
