ls/vtec failing after damper fall.
hi, My car had a weird noise, so this morning I start it and let in idle while looking for the noise. Suddenly the damper fell off and the engine die. The belt never came off completely but skip 2 thoots.
After assembly, the engine start right on, but wit a misfire. I quickly believed a bent valve, so I proceed to perform a compression test.
4- 210
3- 210
2- 210
1- 215
The time is on spot and no check engine, no CKF on the pump. It Struggle a little to start ( like bad Crank sensor).
Any help, Thanks
4- 210
3- 210
2- 210
1- 215
Any help, Thanks
