IAT wiring help with prege silinode.
So I bought the car just over a year ago (98 integra gsr) was a amarican car but got traded in to Ottawa Honda Ontario Canada. Some one test drove it blowing up the stock gsr motor(back in 06) and a kid at Honda bought it and put a b20b with pr3-1 head I think it's a 95 head.
Problem - check engine light on for 10. I replaced the sensor from a junk yard once and my old b18b once code never cleared after reset ecu with fuse 7.5a out for ten minutes. So I looked at the wires and there's a red and a green/white wire to it.(I've been looking that up for days....purge control silinode but where is that located ???). There is the correct IAT wires I think just above the oil pressure wire near the oil filter but I'm not sure what that is. And so far car runs ok but I've read it can fri the ecu. Please help wire wiring thank you
Powered By Garrett
02-17-2007 08:31 AM
