91 crx build needing help
Hey everyone I got a 91 crx si that im trying to build. Im doing a pr3 dohc vtec head on a b18b1. This setup ran perfect in my civic so I wanted in this setup in my crx but turbo. Got me eagle rod n cp pistons, got kings complete bearing set, new rings, arp studs n bolts, a shim spacer, n block gaurd.
For the head i went with skunk 2 spring retainers, n supertech stem seals n seats. I missing valves due to lack on mullah.
But here the tuff part...
The previous owner had thrown in a turbo gsr n wiring looks like hell. Also the ecu looks like work was done too n I've noticed on the engine hariness its got eclipse injector clip, n dizzy had obd1 plugs. But the confusing part is it got an obd0 ecu. A pr3-003 n its got some eclipse chip in it. Im very lost in wat to do. I can't afford to spend money on it n I've read all I can on wiring.
Anyone with superior knowledge plz help me out. It will greatly be appericated.
Treezy
12-29-2014 05:34 AM
wherethefocowe
05-25-2005 06:23 PM
