b18c5 type r swap into 91 civic sedan
Old 03-28-2015, 01:18 PM
Cuninlyngus's Avatar
Default b18c5 type r swap into 91 civic sedan
Hey, I'm currently researching engine swapping and would like to put a b18c5 type r engine into a 91 civic sedan. I've never done this before. I'm wondering if anyone could tell me whats required to do one of these procedures..I know id need a compatible transmission, what else is needed? also should I go with this engine or is the b18c1 a cheaper easier route to start with?
Old 03-28-2015, 02:37 PM
footwork mastery
.Grimace's Avatar
Default Re: b18c5 type r swap into 91 civic sedan
It's sadly not possible. B series swaps have been around since the early 2000's in EF cars there just isn't any info about it.
Old 03-28-2015, 02:41 PM
Technical Hero
HondaPartsHero's Avatar
What trim is your car, EX, LX, etc?
Old 03-28-2015, 04:33 PM
Keyboard Humorist
4drEF's Avatar
Lol!
Heaven forbid that anyone try searching in Google.
Old 03-28-2015, 04:47 PM
footwork mastery
.Grimace's Avatar
What's a "Google"?
Old 03-28-2015, 11:28 PM
I know that its possible I've seen plenty around the internet...it would be most likely be dx I don't have it yet
Old 03-28-2015, 11:30 PM
I just wanted to know what other parts have to be changed besides the engine and tranny for it too work
Old 03-28-2015, 11:57 PM
i think i figured it out if i order one from hmotors they should include everything i need. and from reading some threads they seem legit
Old 03-29-2015, 04:16 AM
Technical Hero
You'll need a bit more. Your car is a DPFI, you'll need to swap over to MPFI and convert your alternator,injector and distributor plugs to OBD2. You'll also need to wire up VTEC and knock sensor along with adapting the fan switch to the thermostat housing. You'll also need to add wiring for the 4 wire 02 sensor.
EF Swap Guide.
CIVIC4G.COM - Honda Civic 4th Generation (1988-1991) Forum ? View topic - Engine swap guide, FAQs and Index thread
Old 03-29-2015, 09:20 AM
thanks man!^
Old 03-29-2015, 11:38 PM
In regards to switching to obd2 I would need a conversion harness right? Also I heard going from obd0 (which the car has) to obd2 can be tricky? Is it possible too convert to obd1 and get a chipped ecu? if so what ecu would I get? Soooo many questions hahaha
Old 03-30-2015, 01:01 AM
Ferio Wdm Edition
ferio-ichi3's Avatar
Youll need a b series ef post mount. I have one if you need it. Just have to find it lol.
Old 03-30-2015, 02:17 AM
Technical Hero
You can convert to OBD1 at the ECU very easily with an adapter harness, however the connectors at certain sensors need to be swapped to OBD2 in order to plug an play, this is after your DPFI harness is converted to MPFI. There are some harness makers out there that will do this for you and add whatever connectors you need to the harness but its pricey. If you are super comfortable with wiring, soldering, etc you can do it yourself. In the FAQ there are a lot of write ups for it.
Old 03-30-2015, 09:33 AM
thanks you're all a great help! I'll let you know if I end up needing that post mount ferio don't try finding it yet haha
Old 03-30-2015, 03:00 PM
I'm browsing Rywire right now for this swap would I need the following: alternator adaptor, some sort of b series harness, a distributor adaptor, and ecu jumper, and injector adaptors?
I'm basically looking for some assistance in what to buy for the wiring part of the swap.
Old 03-30-2015, 03:01 PM
would i also need a 4 wire o2 sensor?
Old 03-30-2015, 09:17 PM
http://www.hmotorsonline.com/shop/sc...age&item=30010
if i order that which includes a whole bunch of stuff. what else would i need to get?
Old 04-01-2015, 03:20 PM
Technical Hero
Instead of all the adapters I'd contact them or monotech and see how much a DPFI to OBD2 engine harness would run.
Old 04-01-2015, 03:29 PM
that way it would cut down on all the wiring and be a little cleaner?
Old 04-01-2015, 05:03 PM
Technical Hero
Yeah definitely
Old 04-01-2015, 05:19 PM
okay thanks for help man appreciate it ill be contacting Rywire once I have the money
Dessus
06-13-2014 12:15 PM
B18CGSRtrans
07-16-2006 10:56 PM
s0apgun
10-21-2004 09:44 AM
CarlCarlson
Acura TL, RL & ZDX
04-09-2003 05:51 AM
Quick Reply: b18c5 type r swap into 91 civic sedan
