1984 CRX MONSTER SWAP
Okay here it is I wanna do something I kinda don't think has ever been done before. I got a 1984 Honda crx carbureted 1.5 "BORING" Im pulling the motor-trans-wiring harnesse ect out of it. OK heres the deal im taking a J32A2 CL (Type S) and going to stick this monster of a engine into this little shell, heres everything I have currently bought for this monster of a swap - Motor
- Hydraulic Six Speed LSD Tranny
- ECU
- Axles with Half Shaft
- Shift Cables and Shift Box
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Coils
- Engine Harness
I need a place for my swap mounts to be purchased.. so far I have right around $4800 in this project. any further help would be greatly appreciated, this is a racecar not a street car. its being built to smoke a buddys junky neon and a B series Delsol. thanks for any help
- ECU
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Coils
- Engine Harness
Screw you guys, I'm... going... home.
Re: 1984 CRX MONSTER SWAP
- ECU
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Coils
- Engine Harness
- ECU
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Coils
- Engine Harness
You might want to talk to this guy first...
https://honda-tech.com/hybrid-engine-swaps-18/h-car-85-crx-j35-3087719/
It's kinda already been done. At least mounted in the chassis.
