ENGINE SWAP ISSUE PLEASE HELP
Old May 18, 2015 | 01:25 PM
4drboostking's Avatar
Default ENGINE SWAP ISSUE PLEASE HELP
I recently swapped a GSR motor out of a 95 integra into my 99 civic hatch and am having an issue with the crank position sensor code. I am running the obd1ecu with a jumper harness. Car runs fine for about 15 min or until I get on it then cel comes on it it goes into limp mode. How do I fix this problem since the obd1 motor doesn't have the sensor by the crank pulley?
Old May 18, 2015 | 09:01 PM
MOTORVATIONS's Avatar
Default Re: ENGINE SWAP ISSUE PLEASE HELP
The sensor around the crank gear is called the CKF (Crank Fluctuation Sensor). You stated that you are getting a CKP (Crank Position) code... which makes sense because an OBD-1 ECU doesn't have the CKF sensor circuit anyway. Your problem is in the distributor. First, check your wiring pin outs and verify continuity from the dizzy back to the ECU plugs. Do not leave out your jumper harness or your dizzy adapter if you have one. If you have an aftermarket distributor, like from Auto Zone, Advance, O'Reilly's, NAPA, etc... consider it suspect.
Good luck.
Old May 19, 2015 | 02:37 AM
HondaPartsHero's Avatar
Technical Hero
civic1999si
Nov 2, 2019 06:25 PM
vtec93accord
Apr 4, 2008 05:24 PM
91BlueEF9
Nov 1, 2007 10:53 AM
Pony_Fed95
Jan 17, 2006 01:51 PM
rev2ninetyper
Jul 29, 2004 10:37 AM
