rywire harness
Old Feb 26, 2015 | 03:25 PM
710dabber's Avatar
Default rywire harness
So im looking at buying a rywire harness will it just plug n play to everything including my p73-003 ecu ?
Old Feb 26, 2015 | 03:33 PM
1991_crxsi's Avatar
Default Re: rywire harness
Contact rewire and ask them. They make custom harnesses for almost any Honda application so I imagine they can make one for whatever you have/need/want.
Old Feb 27, 2015 | 07:13 PM
br8crumb's Avatar
Depends on the setup you plan to run.
All rywire harnesses use OBD1 ecu plugs, so you must run a obd1 ecu. You can however customize the harness so you can use obd1 or obd2 plugs like distrib/alt etc, and you choose the chassis plugs and if you want a seperate charge harness.
Also keep in mind this is a tuck harness which implies relocating fuse box and headlight wiring on older cars.
To answer your question though, it is 98% plug and play. There is a seperate charge harness in most situations and you splice 4-6 wires for power from the chassis plugs.
** iv only used them on crx's, all depends on ur setup it. but it took me less then 3mins to cut/twist the wires and fire the motor right up**
wfocrx
Apr 30, 2015 05:56 PM
912fourtysx
Sep 30, 2011 08:40 AM
EnVme
Engine Management and Tuning
Apr 21, 2009 04:24 AM
nello a.
Dec 24, 2008 12:20 AM
B18CUL8R
Dec 23, 2008 09:58 AM
