Vtec not engaging???
Old Mar 11, 2015 | 12:44 AM
Crazyycivic98's Avatar
Default Vtec not engaging???
There lotsof write ups.. On vtec not working or engaging? But i cant find my answear.. Yet..anyways. So i have lsv with b16 head on my ek.. ..i replace the vtec gaskets..bout 2-3 weeks ago..just tought it be time to change the gasket since i bought the head with unknown milage and since they was kind leaks around that area too....well head works perfectly ..so before i change the gasket vtec will crack in good at 5200 rpms chipp ecu p75...wen i was changing gasket they where dirty and black lil dirt or something on the meshy looking thing.? Anyways so i replace both of them i started the car and no leaks or anything i make sure plugs where plug in correctly and they where...and i was low on oil and i added more oil..ad still vtec wont crack in..
Iknow there lots of post bout this but do you have to take out the battry terminal when you replace the gaskets becuase i dint doo that..? I doubt it will b the other things that ive been reading on other post...?
Im jist tryna see if my vtec solenoid coulnt **** gone bad since i dint took of the battery ? Can that b possible?
Just tryna get my asnwear prob this happem to other people...thanks.
Old Mar 11, 2015 | 02:53 PM
Default Re: Vtec not engaging???
Bump
Old Mar 12, 2015 | 03:56 PM
HondaPartsHero's Avatar
Technical Hero
Do you have a code?
Old Mar 16, 2015 | 04:53 AM
Originally Posted by HondaPartsHero
Do you have a code?
I did once i switvh out my ebay jumper harness to rywyire jumper harnnes i got cel 22 ... Then i check my selenoid if it works.. Connecting it to the battery... N it clickk and after dat happen i was thinking it will be the oil switch n i turn on the car n no more check engine light.
Never comes up again but no vtec
Old Mar 16, 2015 | 06:26 AM
SpeedRacerEX-R's Avatar
Wire in a light on the oil pressure switch on the switched power side. But usually if it wasn't working it would throw a CEL. What makes you think it's not working?
Old Mar 16, 2015 | 08:39 AM
I was thinking of doing that anf also of bypassing it ...and i don hear.. Im running 4-1 type r header not rep..2.5 straight pipe Nd stock eg muffler...sp wen in high rpms is just all motor sound nd i dont hear the other sound vtec.. My friend dont hear it either?
Old Mar 17, 2015 | 07:02 PM
1990accordpnw's Avatar
Did you get it working? Vtec only has so many things it needs to engage. If your wired up correctly and your Vtec worked before you changed you gasket than its mechanic error. Parts don't go out while it isn't running. If it worked before you started your gasket change than it should work afterwards.
Old Mar 25, 2015 | 03:09 AM
It workss know.....good.. Its weird .. Thoo. Prob the new gaskets had to break them in or something ... It should hit at 5200 but i ntice aroud 5500ishh it hits.. And my oil light comes up once in a while even tho my oil is finee... But yeaa works know..
Old Apr 4, 2015 | 06:13 AM
antrmo's Avatar
oil light coming on means low pressure....thats a vtec killer right there.
Old Apr 6, 2015 | 06:47 AM
stock95coupe's Avatar
How do you "know" your oil pressure is fine? W/o a gauge then trust the dummy light, especially if you have another symptom related to low oil pressure. I'd highly recommend you at pull your oil pan off to see if the pump intake is blocked, and I'd certainly recommend getting an oil gauge (even if temporary).
Old Apr 10, 2015 | 01:23 PM
Vtec been hitting good ...ima do an oil change and get fresh new oil on the motor.. And if the lights comes up.. Il put in a light and go from there ? And plus i am past the line on oil so there no oil leaks or any oil needed .. Other than oil change..
Old Apr 13, 2015 | 05:55 AM
b18a1crxsi's Avatar
Did u maybe put the head gasket on backwards so its blocking the oil port that feeds the vtec solenoid? Or if its a b18a1 block is the oil feed line hooked up i know the h22 heads there a 10mm bolt rite above the header that u can remove to test the oil pressure in the head. I think its 6x1.00 threds so u mite need a adapter to pipe thred to screw a 5 dollar 0-100 pressure gauge and make shure its around 8-10 psi at idle and around 50psi at 3000rpm
Old Apr 13, 2015 | 05:01 PM
I dont think so since i remeber how the old gasket was . It had the little screen towars inside. Easy i dont think and there no more leaks and kicks in nice . So idk how it stop for a while and started working . !? It started working once i got a wire and put on battery to the vtec selenoid ? It click and a day or two it stared working
Luca
Sep 17, 2009 12:26 PM
turboteg185
Dec 28, 2007 08:42 PM
eg6madness
Oct 10, 2007 11:05 PM
stickeyfingaz
Dec 29, 2004 10:19 AM
kin_8
Jul 9, 2004 05:41 PM
