B20B into 99 Civic EX
hey guys need help for the ones that really have Honda knowledge... I have a 99 Civic EX coupe I want to swap a B20B into it.. can anyone help me with a list of what I need and will it be plug n play with the harness please help!! thanks in advance!!!
Re: B20B into 99 Civic EX
Besides the obvious(mounts, shift linkage, axles etc) youll need a obd2b distributor, obd2 alternator, you can use your stock injectors.
Technical Hero
You'll need an OBD2B-A distributor adapter. You'll have to put your intake air temp sensor into your intake arm or swap over to a round connector. If you use a USDM ECU you'll have to bypass the CFK sensor by the crank. All OBD2 alternators are the same so it will plug and play. Starter will have the same connections. Just use the B20 injectors. Other than that it should be plug and play.
https://honda-tech.com/honda-civic-d...-vtec-2987229/
white_ej6
11
12-12-2010 04:02 PM
nappyracing001
08-16-2010 05:41 AM
sk8shorty012
07-19-2008 08:14 PM
