Fitting LS Dizzy on Ls/Vtec? How to:
Old May 10, 2005 | 02:44 PM
B16'D DA9's Avatar
Default Fitting LS Dizzy on Ls/Vtec? How to:
Just wondering how its done, I know 1 of the legs dont line up so you have to cut it off, just want to know if anyone has instructions on exactly how its done?
Old May 12, 2005 | 12:45 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Fitting LS Dizzy on Ls/Vtec? How to: (JayDeeEmDC4)
I had the same problem...I didn't want to destroy a good LS distributor housing so I decided to get a brand new B16 (TD-44U) dizzy from DISTRIBUTOR KING 1-866-699-5464. Hit them up because their prices are very reasonable and the products look great!!!! Plus you get a 20% discount if you mention that you are a H-T member.
Old May 12, 2005 | 01:35 PM
B16'D DA9's Avatar
how much was your dizzy i need a obd1 b16
Old May 12, 2005 | 03:22 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: (JayDeeEmDC4)
I paid $180 for it...shipped. Give them a buzz.
Old May 12, 2005 | 10:31 PM
ReV LiMiT's Avatar
Default Re: (NVturbo)
one of the 3 legs on the LS distributor have to get cut off... i think i have one laying around in my garage, if i have time tomorow ill take a picture of it and post it up....
Old May 13, 2005 | 10:38 AM
hybridej7's Avatar
Default Re: (9d DA6 TEG)
im about to put a jdm b18c into my 97 civic hx, which has a b20 in it now with a vtec harness. how can i get the jdm b18c dizzy to work with my plug? the jdm dizzy has the rectangle plug and my harness has the square plug. ive been told i can take the 2 apart and swap wires......this true? want to avoid buying a new dizzy.....
ive also bought from dizzy king.....
Old May 13, 2005 | 12:48 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: (hybridej7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridej7 &raquo;</TD></TR><TR><TD CLASS="quote"> how can i get the jdm b18c dizzy to work with my plug? the jdm dizzy has the rectangle plug and my harness has the square plug. ive been told i can take the 2 apart and swap wires......this true? want to avoid buying a new dizzy..... </TD></TR></TABLE>Yeap..just make sure the wires correspond on both sides.
Old May 13, 2005 | 01:02 PM
B16'D DA9's Avatar
so it would probable be a hell of lot more worth it to just buy a b16 dizzy from dizzy king for $180 rather than hacking mine up or is it legit to cut off the leg? will there be an oil leak? plus im converting to obd1 and my ls dizzy is obd2? that would be a bitch huh?
Old May 13, 2005 | 01:15 PM
hybridej7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo &raquo;</TD></TR><TR><TD CLASS="quote">Yeap..just make sure the wires correspond on both sides.</TD></TR></TABLE>
cool.....
Old May 13, 2005 | 04:05 PM
91civicDXdude's Avatar
$180 vs. free
you make the call. running 2 bolts will not leak.
you'll need to cut off the front lower leg so it will clear the VTEC solenoid
Old May 13, 2005 | 09:05 PM
FERIOkid's Avatar
https://honda-tech.com/zerothread?id=1245406
Old May 15, 2005 | 07:23 AM
Slavko's Avatar
Default Re: Fitting LS Dizzy on Ls/Vtec? How to: (slowdx9585)
i'm pretty sure that if you try to put a ls distributor on a vtec head that the vtec will not come on.
Old May 15, 2005 | 07:31 AM
FERIOkid's Avatar
Default Re: Fitting LS Dizzy on Ls/Vtec? How to: (Slavko)
^^^ explain that please
Old May 15, 2005 | 07:47 AM
Slavko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowdx9585 &raquo;</TD></TR><TR><TD CLASS="quote">^^^ explain that please </TD></TR></TABLE>
There is some elelctrical thing/sensor(i think) inside the distributor from a vtec head that has to do with the vtec engaging on a vtec head. If you put a non-vtec dizzy on a vtec head, then the vtec will not come on. I know this from experience because I was doing a h22 swap into a integra gs-r and I put a ls dizzy on the vtec h22 head and the vtec did not engage. Swapped out the dizz with a gs-r one and vtec started working.
This is just a theory. If anyone can prove me wrong then please go ahead.
Old May 16, 2005 | 12:07 PM
hybridej7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slavko &raquo;</TD></TR><TR><TD CLASS="quote">i'm pretty sure that if you try to put a ls distributor on a vtec head that the vtec will not come on. </TD></TR></TABLE>
what if you just swap wires? keeping the vtec dizzy on the vtec head, but just swapping the wires inside? all the same except obd0/obd1/obd2?
Old May 16, 2005 | 07:47 PM
FERIOkid's Avatar
Default Re: Fitting LS Dizzy on Ls/Vtec? How to: (hybridej7)
Old May 16, 2005 | 10:51 PM
ReV LiMiT's Avatar
This is just a theory. If anyone can prove me wrong then please go ahead.</TD></TR></TABLE>
im throwing in the b.s. flag with that one.... i had a 90 integra with an ls/vtec running a stock pw0 ecu. i used the factory 90 integra distributor and vtec worked no problem. then i upgraded to an obd1 setup and becuase im a cheap bastard i bought an obd2 ls distributor and vtec still worked. vtec doesnt really have anything to do with the distributor. maybe some thing was up with the h22, i dont know, but of all the swaps my friends and i have done converting a car from non vtec to vtec using the ls distributor or any other non vtec distributor we never had any problems activating vtec.....thats my .02
Old May 17, 2005 | 12:53 PM
NVturbo's Avatar
O.G. triple O.G.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slavko &raquo;</TD></TR><TR><TD CLASS="quote">i'm pretty sure that if you try to put a ls distributor on a vtec head that the vtec will not come on. </TD></TR></TABLE>SORRY bro..but that is FALSE. You can put a non-VTEC distributor onto a VTEC head but it is just that the mounting holes are in different sequence. The holes on a LS dizzy are equally apart while the B16/B18c are more like an upside-down "Y" shaped.... A distributor has nothing to do with VTEC engagement. Make sure of yourself before you post next time.
Old May 17, 2005 | 02:03 PM
Slavko's Avatar
Default Re: Fitting LS Dizzy on Ls/Vtec? How to: (NVturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo &raquo;</TD></TR><TR><TD CLASS="quote">SORRY bro..but that is FALSE. You can put a non-VTEC distributor onto a VTEC head but it is just that the mounting holes are in different sequence. The holes on a LS dizzy are equally apart while the B16/B18c are more like an upside-down "Y" shaped.... A distributor has nothing to do with VTEC engagement. Make sure of yourself before you post next time. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slavko &raquo;</TD></TR><TR><TD CLASS="quote">This is just a theory. If anyone can prove me wrong then please go ahead.
Old May 17, 2005 | 02:25 PM
B16'D DA9's Avatar
Okay so do you all say it is safe to put my ls dizzy on my lsvtec then, need to know im doing the swap just as soon as my ecu comes from ecuhacker.com. I dont want any oil leaks.
Old May 17, 2005 | 04:42 PM
Slavko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDeeEmDC4 &raquo;</TD></TR><TR><TD CLASS="quote">Okay so do you all say it is safe to put my ls dizzy on my lsvtec then, need to know im doing the swap just as soon as my ecu comes from ecuhacker.com. I dont want any oil leaks.</TD></TR></TABLE>
Go ahead and put it on. It won't hurt anything. Just make sure you get the timing right when you put it on because its not going to line up with the vtec head.
organizedrisk
Jan 23, 2006 09:17 PM
Big_S
Sep 13, 2004 06:15 PM
Big_S
Sep 7, 2004 08:17 PM
