LS/VTEC which is better LS Pistons/rods or GSR pistons/rods
LS/Vtec
LS block GSR head
want to know whats better to run
LS rods/pistons
GSR rods/pistons
B16 pistons & gsr rods or ls rods
any info would be great. thanks in advance.
LS block GSR head
LS rods/pistons
GSR rods/pistons
Re: LS/VTEC which is better LS Pistons/rods or GSR pistons/rods (SoOHiGH)
gsr rods dont fit in the LS block. i recently found this out. well, not unless you change the crank also.
i went though gsr rods/itr pistons, gsr rods/gsr pistons, gsr rods/srp turbo pistons, and none of those combos work with the ls crank.
Re: LS/VTEC which is better LS Pistons/rods or GSR pistons/rods (dc2_lsvtec)
o i c.
i have the gsr crank too.
what you think is better a LS or GSR crank?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoOHiGH »</TD></TR><TR><TD CLASS="quote">o i c.
what you think is better a LS or GSR crank?</TD></TR></TABLE>
no point of using gsr crank..then it wouldn't be ls/v-tec
use ls rod's with b-16 pistons...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2_lsvtec »</TD></TR><TR><TD CLASS="quote">gsr rods dont fit in the LS block. i recently found this out. well, not unless you change the crank also.
i went though gsr rods/itr pistons, gsr rods/gsr pistons, gsr rods/srp turbo pistons, and none of those combos work with the ls crank. </TD></TR></TABLE>
You could have just done some simple math and avaoided all that headache.
B16A pistons on LS rods.
Forged and aftermarket always better.
If you use stock B16A pistons you'll have trouble keeping your ring lands in tact.
If you use stock LS rods, for peace of mind, shot peen them and get some arp rod bolts.
Re: LS/VTEC which is better LS Pistons/rods or GSR pistons/rods (sik civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sik civic »</TD></TR><TR><TD CLASS="quote">B16A pistons on LS rods.
If you use stock LS rods, for peace of mind, shot peen them and get some arp rod bolts.</TD></TR></TABLE>
Seriously, where do you guys come up with this ****, "if you use b16a pistons you'll have trouble keeping your ringlands intact" "aftermarket is always better"
To the original poster, use p30 pistons or jdm itr pistons with your ls rods, have a machine shop cut a mm of each side of the small end of the rod if using the itr's, get arp rodbolts and have the rod resized. Use you ls crank
Re: LS/VTEC which is better LS Pistons/rods or GSR pistons/rods (PURPLETERROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR »</TD></TR><TR><TD CLASS="quote">
To the original poster, use p30 pistons or jdm itr pistons with your ls rods, have a machine shop cut a mm of each side of the small end of the rod if using the itr's, get arp rodbolts and have the rod resized. Use you ls crank </TD></TR></TABLE>
gonna use LS rods with crank and im gonna get some p30's but if not, im gonna get si's. o yea with a gsr head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sik civic »</TD></TR><TR><TD CLASS="quote">Forged and aftermarket always better.</TD></TR></TABLE>
Forged pistons are not always better. Yes, they are stronger. But they also have to be run looser. This causes an increase in both noise and wear, which is generally undesirable on a daily driver. The bottom line: if you don't need the strength of forged pistons, don't bother with them.
