Will GSR Distributor work on an obd0 b16?
I was just wondering cause i have access to one, and its obd1 95 gsr distributor, will it run the obd0 b16 without any problems? Did a search and no luck....
Re: Will GSR Distributor work on an obd0 b16? (egvtec)
If you are running a OBD1 ECU and harness it will work. If trying to use a OBD0 harness and ECU it won't work.
Re: Will GSR Distributor work on an obd0 b16? (skunked)
is there any difference at all? i heard there was a difference between the gsr and b16 dizzy?
And yes i have an obd1 harness.
I would like info on this also..
Can I use obd0 dist, obd0 harness, with conversion harness from 0bd0-obd1 to an obd1 ECU?
Crazy Honda Guy
I am running an obd1 gsr distrbutor on my crx converted to obd1. I used the original harness and had the plug for the distrbutor repinned for a clean install.
Re: Will GSR Distributor work on an obd0 b16? (Outsane)
As far as fitting the GSR distributor to a first gen B16, yes it will work but you would need to be using an OBD1 or OBD2 ECU. You can't use an OBD1 (or OBD2 for that matter) distributor controlled by an OBD0 ECU and vice versa. Now as far as OBD1 and OBD2 distributors go, they are fully interchangeable because they are basically the same internally and only the plug style is different (which can be changed really easily).
Re: Will GSR Distributor work on an obd0 b16? (VTECVillain)
ahh.. thats not good news.. now I have get a distributer...
so any vtec dual cam 0bd1 or 2 distro will work with a obd1 dual cam vtec ECU
just want to make sure
Crazy Honda Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane »</TD></TR><TR><TD CLASS="quote">ahh.. thats not good news.. now I have get a distributer...
just want to make sure</TD></TR></TABLE>
Correct.
Correct.
Re: Will GSR Distributor work on an obd0 b16? (Deetz)
Would a gsr distribuer start on a p28 map so i can baby her to the dyno to get my ecu chipped? i know the fuel maps are off but my friend was running one and it seemed ok
You can not use a OBD1 dizzy on a non OBD car. There is no way to make it work,
now if you wire your car to OBD1 then you can use that dizzy. But in less you change all the wiring over its not happen
(Hope this helps)
-Thomas
Oh ya and if you do change over to OBD1 you have to get a new O2 and ECU as well
(Hope this helps)
-Thomas
Isn't the Crank Position Sensor different between OBD 1(in dizzy) and Obd 2(in oil pump?) how do you get pass this without re wiring. I know you can switch them but it would seem modification is needed to go between 0bd1 and obd 2
Re: (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic »</TD></TR><TR><TD CLASS="quote">Isn't the Crank Position Sensor different between OBD 1(in dizzy) and Obd 2(in oil pump?) how do you get pass this without re wiring.</TD></TR></TABLE>
No, the Crank sensor is the same in both OBD1 and OBD2 distributors. You are talking about the Crank Fluctuation sensor on USDM OBD2 motors which is on the oil pump. That is a separate sensor all it's own for OBD2 cars.
Crazy Honda Guy
Re: (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">
No, the Crank sensor is the same in both OBD1 and OBD2 distributors. You are talking about the Crank Fluctuation sensor on USDM OBD2 motors which is on the oil pump. That is a separate sensor all it's own for OBD2 cars.</TD></TR></TABLE>
Thats cool, i was wondering about that other sensor myself. When i dissmanteled a B16B last year it was a 2000 model and didn't have it, i wondered why?
ryanangelo212
03-18-2013 12:23 AM
xotic_crx
05-20-2010 08:33 AM
chirp2hrd
05-02-2003 04:26 PM
