I'm having the worst swap luck ever. Please someone help me yet again. I just got some GSR axles. I ran into a problem with the driver side. The end of the axle that goes into the intermideate shaft is too big or the intermediate shaft is too small. Is there a difference in the intermediate shaft between the B series? If so, what driver side axle do I need to get? If that's not the problem what do you think is the problem?
Does you intermedaite shaft have a male or female end where the axle goes in.
It has a female end. But on the axle end that would go in the intermediate shaft there is a end that has grooves in it like the end that goes to the hub. The intermediate shaft doesn't have a hole for that to go in. Do you think i have the wrong shaft or a wrong axle??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatcivic213 »</TD></TR><TR><TD CLASS="quote">It has a female end. But on the axle end that would go in the intermediate shaft there is a end that has grooves in it like the end that goes to the hub. The intermediate shaft doesn't have a hole for that to go in. Do you think i have the wrong shaft or a wrong axle??</TD></TR></TABLE>
What do you mean it doesn't have a hole for the axle to go in? You're not really maing any sense, can you post a picture of what you're having problemns with?
I figured it out. I just went and bought a new shaft.
