p54 a/c tension wheel
1 Post
Re: p54 a/c tension wheel (pdiggitydogg)
what year D16?
from what i've found,there are two different style tensioner wheels.
the "pivot" style:
and the "slide" style:
if your D16 has the same style as the P54 bracket(which i believe has the pivot style),then you can use it.
Chris
the "pivot" style:
Chris
Re: (pdiggitydogg)
i didnt use a tensioner. i have an unorthodox underdrive pully and i got the belt 28.5 inches long and it was a little tight when i got it on but i started up the engine and ran for a few min and then i shut it off and it had perfect tension.
Re: (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 »</TD></TR><TR><TD CLASS="quote">slide style rocks! </TD></TR></TABLE>
Why post that? It has nothing to do with anything...
The part numbers are the same for the wheels (slide or pivot), but the bolt that holds them is different.
Oh, you mean like is there a difference between one slide style adjuster and another slide style adjuster? I doubt it, but knowing Honda something small and asinine like that would be.
Not slider, pivot style.
Im really asking if one is another size. Ive never seen the actual brackets to know. But it wouldnt surprise me if one is different. (and w/ my luck, I'd buy that one and be screwed)
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">Not slider, pivot style.
Im really asking if one is another size. Ive never seen the actual brackets to know. But it wouldnt surprise me if one is different. (and w/ my luck, I'd buy that one and be screwed)</TD></TR></TABLE>
Ok, I got you now. You know, I have both, one I know where it's at, but the old one I replaced is in a bag in my basement. If no one hits this up before tomorrow, I'll go look when I get home.
nyce1
07-11-2012 06:33 AM
RACEPAK
07-11-2005 03:17 PM
HondaCutter
08-09-2003 07:17 PM
