Type-R Transfer
Old May 12, 2005 | 10:24 AM
EgRedSi's Avatar
Default Type-R Transfer
I'm doing a B18C-R swap into my EG and I have a few questions. It's the 98+ spec with the 4.7 final drive and 4 to 1 header.
Does the radiator that use have to be based off of the motor or my car? Meaning, it's an ITR motor but does that mean it'll fit and EG?
Do I have to raise my car? I'm running 15in Rota Circuit 8 on 195/50/15 on Fuzion ZRi's, there's virtually not space between my fender and tires. Do I have to raise the car at all or will the motor be a safe distance from the ground. The body of the car sits about 4 inchs off the ground as it is.
Lastly, is the header and 4.7 final drive worth $400 extra bucks? Does it make that much of a difference?
I would've posted this in the EG forum but I figure I should ask people who own the motor.
Modified by EgRedSi at 9:13 AM 5/15/2005
Old May 12, 2005 | 10:30 AM
p nut's Avatar
https://honda-tech.com/zeroforum?id=18
Old May 12, 2005 | 10:35 AM
cmdr430's Avatar
Default Re: Type-R Transfer (EgRedSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EgRedSi &raquo;</TD></TR><TR><TD CLASS="quote">
does the motor come w/ the tranny? if it does it should already have the final drive in it......
so, no the header is not necessarily worth $400
you should be fine w/ the eg radiator......
your ground clearance should be fine w/ the jdm header..... but i would raise the car anyways.... it does not need to be slammed to handle well......
Old May 12, 2005 | 11:03 AM
EgRedSi's Avatar
Default Re: Type-R Transfer (cmdr430)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">
The motor comes with the Type-R tranny (hydro) but the final drive changes depending on how much money you spend on it. Regular it comes with a 4.4 final drive and for $400 more come with the 4-2-1 header and a 4.7 final drive. That's worth it right?
Old May 12, 2005 | 11:07 AM
EgRedSi's Avatar
Default Re: (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zeroforum?id=18</TD></TR></TABLE>
I see what you're saying.
Old May 12, 2005 | 11:15 AM
jeremy.'s Avatar
Default Re: (EgRedSi)
yes it is worth the extra money...u park your car at the barracks at miramar...think i saw your car there
Old May 12, 2005 | 11:23 AM
Jon D's Avatar
My man...if you are buying JDM ITR motor with a tranny that has a 4.7 FD you are not going to be getting a 4-2-1 header. You will be recieving a JDM 4-1 header. Only the 96&97 spec JDM ITR motors came with the cast 4-2-1 manifold as well as all USDM Type Rs.
Damn this is beaten information.....
Old May 12, 2005 | 11:25 AM
EgRedSi's Avatar
Default Re: (ekay_jeremy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon D &raquo;</TD></TR><TR><TD CLASS="quote">My man...if you are buying JDM ITR motor with a tranny that has a 4.7 FD you are not going to be getting a 4-2-1 header. You will be recieving a JDM 4-1 header. Only the 96&97 spec JDM ITR motors came with the cast 4-2-1 manifold as well as all USDM Type Rs.</TD></TR></TABLE>
So that's a go right? It's worth it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekay_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">yes it is worth the extra money...u park your car at the barracks at miramar...think i saw your car there</TD></TR></TABLE>
It was probably someone else
Old May 12, 2005 | 01:16 PM
EgRedSi's Avatar
Default Re: Type-R Transfer (Jon D)
Spoon ECU or what, I want to be able to rev till 9800rpm
Old May 12, 2005 | 01:25 PM
jeremy.'s Avatar
want to rev to 9800 or make power up to 9800????
Old May 12, 2005 | 02:23 PM
EgRedSi's Avatar
Default Re: Type-R Transfer (ekay_jeremy)
Rev, I'll probably won't take it past 9000rpm.
Old May 12, 2005 | 04:16 PM
EgRedSi's Avatar
Bump
Old May 13, 2005 | 09:01 AM
EgRedSi's Avatar
Bump for a good answer.
Old May 13, 2005 | 07:38 PM
EgRedSi's Avatar
Bump
Old May 15, 2005 | 08:16 AM
EgRedSi's Avatar
Bump........wow, I'm virtually talking to myself
Old May 16, 2005 | 01:19 PM
EgRedSi's Avatar
How are you doing?
Old May 16, 2005 | 04:33 PM
Kapman38's Avatar
On stock intrenals, would not go past 9K...
Stock ECU is 8400... Best bet is go Hondata S100, I have that in my tuned ITR motor..
Old May 16, 2005 | 05:00 PM
Aloha04MSM's Avatar
i did a jdm itr swap in my dc2. i already had the 98 spec tranny so i just go the 96 spec motor swap because it was cheaper. i should have still payed the extra 400 because the header is worth at least 250 and then i at least would have had that. but ne wayz, are you getting the motor from hmotorsonline.com? i highly reccomend them. my swap passed tail pipe with flying colors. but remember, if you plan on doing the swap, you are going to need to run a us intake manifold, tb, evap canister, and ecu to be able to pass smog if you get sent to the ref. I didn't know that until 3 days ago. now i need to fork out like 7-800 bucks just to get my car deemed legal. good luck and enjoy. best money ever spent on my teg.
Old May 16, 2005 | 05:20 PM
EgRedSi's Avatar
Default Re: Type-R Transfer (Kapman38)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kapman38 &raquo;</TD></TR><TR><TD CLASS="quote">Stock ECU is 8400... Best bet is go Hondata S100, I have that in my tuned ITR motor..</TD></TR></TABLE>
I just want an ECU that would let me rev past 9rpm, although I wouldn't take it that far.
Hondata huh? What makes them so good?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cinteg96 &raquo;</TD></TR><TR><TD CLASS="quote">hmotorsonline.com? </TD></TR></TABLE>
You got rims on your car yet Clint?
Old May 16, 2005 | 06:05 PM
Kapman38's Avatar
They can tune the engine and A/F curve to whatever mods you add to engine. Can also set rev limiter, but most mods do not make power past 9K. Not in a stock piston set up.
Your $$$ to power ratio would way too much to rev a ITR motor that high.. unless its for strip only...
Go to http://www.hondata.com for more info..
Old May 17, 2005 | 08:20 AM
EgRedSi's Avatar
I know nothing about final drives, what's the difference between 4.4 and 4.7 so where it's $400 more
Old May 17, 2005 | 08:44 PM
Kapman38's Avatar
it is a lower first gear, and final drive is shorter. Basically let you acclerate faster and stay in power zone of engine in all gears, but revs higher and a little buzzy in fifth...mine runs 3300 at 60 mph... But much better for spirited running...
Well worth $400 in all respects...
1993eghatch
27
Sep 20, 2010 02:48 PM
crx-r1
Mar 18, 2004 05:50 PM
MXPX
Jun 20, 2002 02:38 PM
