???garbage motor???
???garbage motor???
just wondering if anyone's ever tried this on here. If you dont no what it is its a b16 block on an ls head. any one got info on this at all. mite be interested in doing one didnt no if anyone had info on it. i did alot of searches and came up ***** short.
Re: (burnitup)
Um I dont see how its possible for it to be better then the LS/VTEC because it would be a 1.6 non vtec instead of the LS that is a 1.8 and taking the vtec away from a b16 is not going to make it faster at all. Personally ive never seen this or heard of ne one doing it I think it sounds plain ridiculous.
idk something about more usable traction because of the whay there is not as much torgue or hp so your no spinning tires all the way down the track. plus the rs goes up as well.
You'd lose compression ratio, LS heads dont flow as well, and the absence of VTEC. I'm not sure why you'd do this unless you were desperate and didn't have a head. I think a complete LS motor would probably make more power than a b16 block and ls head.
Re: (burnitup)
an LS vtec is a decent swap because you take the best parts of both motors to make one more powerful than the b16 or the b18 alone. so doing the opposite will leave you with a motor less powerful than either. the bottom end has no torque, and the valvetrane in the head limits your revs. sounds like a good swap if you are broke, have no engine and need to get you from point a to b. that way you can swap for a real B series motor down the road without replacing many parts. I bet it would only be slightly slower than a sohc vtec.
i guess i have seen that guys car that ran this set up with 57 trim i think hey ran like 12.8 or low 13s but not positive. i dont care i waw just wondering if any one had done this or not?
Re: (burnitup)
dude if you go that set up you better be running some really high duration, huge lift cams.... so that way you wouldnt have vtec but with those you wont need it anyways...
akoreanyoungsta
05-10-2006 10:10 AM
davidcrx89
06-23-2005 01:07 AM
