Need help with b18b/ef swap
I bought a JDM 94 B18B and got the motor and tranny in the car, everythings been wired to MPFI and so I went to go plug everything up and basically nothing fits. I can understand the distributor but the injectors is what has me baffled. I've never seen connectors like this before. They have an offset notch instead of centered with black connectors with a blue insert. Also, the motor doesn't seem to have as many"connection points" as the harness. My biggest problem though is my water pump. The one on the b18b doesn't fit inside the car. Does any one know which water pump should fit?
Please help
Please help
Re: Need help with b18b/ef swap (Redlineracer)
Boy do I feel like a dumbass....Let this be a lesson for you boys and girls when you start mistaking a power steering pump for a water pump, its time to stop and go home. I'm going to bed now....
