90-93 Accord Intermidate shaft, w/ 86-89 teg axles
Old 05-09-2005, 05:31 AM
patastinky's Avatar
Default 90-93 Accord Intermidate shaft, w/ 86-89 teg axles
has anyone tried this set up yet?
Basically using the accord 90-93 mid shaft, w/ the 86-89 teg axles. Them swapping out the inner cv joint and putting on the accord inner joints so that they fit the 90-93 accord mid shaft?
Basically taking the same principle you would in using the prelude mid shaft and 86-89 teg axles.
what do you think? Anyone try this or think of doing this?
Old 05-09-2005, 05:43 AM
patastinky's Avatar
Default Re: 90-93 Accord intermediate shaft, w/ 86-89 teg axles (patastinky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman
&raquo;
</TD></TR><TR><TD CLASS="quote">If your axles bind on the driver side, and if you're using the 90-93 Accord intermediate shaft, you can use the 88-89 Integra axle since it's an inch shorter and use that with the Accord intermediate shaft. Haven't run into axles binding on the driver side when using the Prelude intermediate shaft & 88-89 Integra axle w/Prelude inner joint</TD></TR></TABLE>
hmm, isn't the prelude driver side intermediate shaft a MALE and the accords intermediate shaft a female ? So how could the driver side 86-89 teg work on both intermediate shafts if the teg driver side inner joint is a female./??
to slow
01-22-2007 02:18 PM
tdo
11-23-2005 12:24 PM
SixguN
11-22-2004 12:37 PM
jdmcivicferio
12-24-2002 01:15 AM
OEMJDM
09-14-2002 07:30 PM
Quick Reply: 90-93 Accord Intermidate shaft, w/ 86-89 teg axles
