Need Help With B16a1 swap Into A CRX HF!!!
i have a crx hf. i switched out the full wiring harness and hubs. i went to test fit the engine and it does sit right. the whole motor seems like it sits too far towards the front, almost on the cross member. i got the motor mounts on ebay and they seem to be right, i compaired them to others in pictures. i can get pics if needed. please help!!
Re: Need Help With B16a1 swap Into A CRX HF!!! (crx_soldier)
Whats your question really? Do you think your motor sits too far forward? I also have an HF w/ B16. My mounts make the motor sit more forward (than most seen) as well. The bolts for my header (2 piece) actuallly sit on the crossmember, so I had to notch it out, but other than that everything is fine. You can change the mounts if you want, but I think the difference is probably 1-2" back in position. There is no way you could put an a/c fan in my car, unless it was super slim due to clearance between my header and radiator
Leonard Esquire III
04-10-2006 11:00 AM
kleanlscivic
34
08-12-2005 03:39 AM
