HELP PLEASE...
Old May 15, 2005 | 09:16 AM
Kool305's Avatar
Default HELP PLEASE...
B16a swap...okay so when i turn the car ON in the morning when its cold...it suppost to idle around 1500 RPM's well and eventually just idle normal...in the past two days it has been idleling at about 300 RPM and then it goes from 3 to 800 up and down after twenty seconds of running the car...once its warmed up ...it idles perfect...whats up with that?
thanks in advance...
Old May 15, 2005 | 09:31 AM
hondaZvic's Avatar
Default Re: HELP PLEASE... (Kool305)
timing might be off...
Old May 15, 2005 | 09:35 AM
Kool305's Avatar
i first thought it was a vacumm problem...i tighten the intake manifold...
checked all the hoses...even played around with the idleling screw on the tb (*throttle body*) and nothing...so timing huh?...hmm ...anyone else wants to take a shot at this....btw VTEC works
Old May 16, 2005 | 02:04 AM
Kool305's Avatar
next thing i ll check will be the IAVC...ANYONE PLS HELP...
Old May 17, 2005 | 05:40 AM
Kool305's Avatar
Default umm NO THANX
apparently the chip im running now (fuel economy purposes)
well it reads knock sensor and some other misc sensors which i happen to have
Disabled with my other computer set up...so...
i fixed the codes and the car is happy...
btw didnt know that CODE 6 affects timing and other misc stuff...damn hondas...
anyways im glad i was able to fix this one on my own...
Old May 19, 2005 | 01:15 PM
Quitripin's Avatar
Default Re: umm NO THANX (Kool305)
check the timing
TheJakePatty
Jul 27, 2011 09:39 AM
superfast666
May 29, 2008 08:46 PM
freakasis
Feb 24, 2007 01:27 PM
rtiadnoh
Feb 24, 2004 04:44 PM
