mating gsr head with b16 block
I have a Obd2 Gsr head and a Obd2 b16a2 block....
is there anything needed to match these together? Is the headgasket the only thing needed to bolt this motor togehter? is this a disadvantage to having a full gsr?
DYNO-PRO
Location: SoCal I.E 909, CA, where we innovate not immitate
Re: mating gsr head with b16 block (tphan4)
IT WILL HAVE .2 LESS COMPRESSION , bit other than that no, just bolt it on and the head gaskets are the same
Re: mating gsr head with b16 block (HOOKUPS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS »</TD></TR><TR><TD CLASS="quote">IT WILL HAVE .2 LESS COMPRESSION , bit other than that no, just bolt it on and the head gaskets are the same</TD></TR></TABLE>i think that it will raise the compression by .2 due to the closed chamber design of the gsr head
Guest
Posts: n/a
Re: mating gsr head with b16 block (reactiondc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reactiondc2 »</TD></TR><TR><TD CLASS="quote">i think that it will raise the compression by .2 due to the closed chamber design of the gsr head</TD></TR></TABLE>
yep, more copression less displacement, gaskets are the same it's a direct bolt on for the most part, using the GSR thermostat housing makes things a little easier when routing the water hoses.
DYNO-PRO
Re: mating gsr head with b16 block (thad)
yes my bad i thought he was asking the difference between the two heads gsr = more compression
theneil
01-15-2006 09:17 AM
