Doing H22a swap into 98 Teg... problems with the axles!!!
OK, I've read up on what you need for this swap. We have everything or thought we did. I ordered a 90 Accord Half Shaft with the 90-93 L and R Integra axles. Got the half shaft no problem... went to put it in and both of the ends are male ends, as well as both of the ends for the axles are male ends. The problem is that my buddies who one is a Honda tech and the other has done this swap before say that the half shaft is wrong. It should have a male and female end. I've also asked numerous people who have done the swap already and they said the half shaft has both male ends and the axles are one male and one female. Need help ASAP please! Thanks!
Re: Doing H22a swap into 98 Teg... problems with the axles!!! (Sivik)
I have the same motor and shell and used the lude midshaft and 86-89 teggy axles. From what I read though, your combo should be right (90-93 accord half shaft with 90-93 teggy axles) ... weird. Both ends on your midshaft are female?
Re: (Sivik)
then you must have got the wrong parts, b/c with your setup it should have worked. the intermediate shaft has a male and a female end and you hook up the teg male into the intermediate female. and the same thing on the other side (without the intermedaite shaft). don't forget to swap out lude ends on the teg axles or else it will probably constantly pop out.
yea we figured out the shaft was wrong... i read about the swapping of the lude ends... is this necessary because they will fall out constantly or can i get by for the time being?
