ECU Wiring H22/Civic [Pls guys..]
So..i need to re wire some cables to get it run prop.. , like knocksensor and Vtec solenoids n so on..
Pics?..info? , pls share if u got
EDIT: I got a 94 Hatch DX non vtec (EG3) with a JDM H22
// Jonas
// Jonas
Re: ECU Wiring H22/Civic [Pls guys..] (GOFASTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOFASTR »</TD></TR><TR><TD CLASS="quote">So..i need to re wire some cables to get it run prop.. , like knocksensor and Vtec solenoids n so on..
// Jonas </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1171263
Re: ECU Wiring H22/Civic [Pls guys..] (1dopesi)
hey to answer your question, are you going to get a chiped ecu later or soon or do you already have one? you probably don't have one yet cause you said your trying to wire up the egr. don't wire the egr if your going to get a dif ecu it will slow it down and you can just live with the engine light for now, its fine. so don't wire the egr, wheni did my swap i printed out a site froma friend that showed step by step on doing the wire harness stuff, i will try to get the site for you and repost it, until then gl
