How hard to move dowle pins on Vtec head?
I have access to all of the stuff to do it, but how exactly do I get the dowl pin out without damageing it?
Re: How hard to move dowle pins on Vtec head? (BLK94RS)
I just gently pulled then out with some pliers. Seems like you're well on your way with this project. Just a few things you may not know that I found out the hard way:
Be sure to have the upper PS bracket from a vtec head. The ls one won't work.
You'll also need the vtec timing belt cover. I hope you have one of the block girdles on your bottom end
Also, if you want the gsr oil cooler setup, I have the everything you need (oil cooler, rear water pipe) except the nipple you tap into the block if you want it. I went with the front mount setup.
[Modified by b18bpwr, 5:40 PM 5/2/2002]
Re: How hard to move dowle pins on Vtec head? (b18bpwr)
I didn't think about the PS & timming belt cover. Man this is getting pretty spendy.
If anyone has those parts, please IM or e-mail me at ryan_kidwell@hotmail.com.
As for the Girdle. For now I won't have it. Its frirst on my to do list when I get more money.
Iv talked to several people now who said it will be alright. They said its more important to get a GSR oil pump.
be careful...because it is aluminum, it wont take much to drill it out. also, tape off that complete surface so no shavings get into any of the little passages, just a suggestion
Re: How hard to move dowle pins on Vtec head? (Jeff C)
What about any shavings that will fall into the hole I am drilling. Or does that not matter really?
pakn-heat
12-01-2009 04:17 PM
