GSR header with O2 sensor for hybrid
I put a ODB1 JDM GSR into my 95 EX. The stock header on the GSR has a hole for an 02 sensor. I went today and picked up a DC sports one piece, 4-1 header for a 94-98 GSR part 6607. I noticed it doesn't have a spot for the 02 sensor. I looked at the 2000 GSR header and it did have one. I'm still using my stock Civic cat, which has no 02 sensor on it.
So which header should I get, and still have everything line up correctly? The 2000 GSR header or something else? Thanks.
Re: GSR header with O2 sensor for hybrid (CivicEx95)
Are you getting codes? If you are running an OBDI P72, you shouldn't throw codes if your cat has no Os sensor, I think it only looks for O2 sensor from the header. I have a 00 gsr motor in my 93 hatch, running an OBDI P72, have an O2 sensor on the header but none on cat and no codes.
Re: GSR header with O2 sensor for hybrid (Guardson3r3)
I'm not getting any codes relating to the 02 sensor, cause I haven't changed anything yet. I'm just confused about my engine, because it's JDM. My stock header has a 02 sensor hole and nothing on the EX cat. But the new GSR header I got today doesn't have a hole for 02. Is that because GSRs of that year have them in the cat? So if I'm going to keep my stock cat, could I just pick up the 2000 GSR header? Will it bolt up to the block with no problems? Thanks.
Put the O2 sensor into the cat pipe. I have a Bosal stainless header and it also doesnt have the o2 bung in it. I had the bung welded into the cat pipe.
Re: GSR header with O2 sensor for hybrid (hybridcivic93cx)
Hey:
I got a Comptech header for a Type R for my 95 CX hybrid. It has a bung for the 02 sensor in nearly the stock location.
Steve
Steve
Re: GSR header with O2 sensor for hybrid (LXguy)
Man just buy a 99-00 Si header and dont worry about anything. The o2 sensor will be perfect and it will bolt to you exhaust.
Re: GSR header with O2 sensor for hybrid (tSuperbike69)
Ok, so I bought a 99-00 SI 4-1 ceramic header, and IT DIDN'T FIT. It's not tall enough! I repeat, IT DOESN'T FIT for a 5th gen civic. I noticed that the bracket was hitting on the oil pan, so I cut off part of the bracket to make room, then I noticed it wasn't tall enough. So now I'm stuck with this header that I can't return, and have no use for.
So If I'm going to get a header, which one do I need? A 2000 GSR header, because thats the only one that has a sensor for the 02? This is pissing me off.
[Modified by CivicEx95, 3:16 PM 5/2/2002]
I am pretty sure you need a b18 header. Buy a DC header for a 00 GSR and try it. The b16 is shorter so the header wont fit. What kind and style did you buy? I might be interested in it if you want to get rid of it.
92SiHatchie
07-22-2003 08:33 PM
