Lowering Compression?????
Old Apr 29, 2002 | 10:04 AM
YellowCivic95's Avatar
Default Lowering Compression?????
Does Lowering Compression ratio reduce horsepower??? Just want to know?
I
Old Apr 29, 2002 | 11:38 AM
JD_B18CDX's Avatar
Default Re: Lowering Compression????? (YellowCivic95)
Yes it does lowe HP and Torque
Lower comp = less cyl presure = less HP and torque.
The benefits are.....
Lower com = less cyl presure = less prone to knocking.. therefore u can use cheaper fuel with less octane.
Old Apr 30, 2002 | 05:29 AM
HKxBlur's Avatar
Default Re: Lowering Compression????? (johnd)
... and run greater boost levels or nitrous into the motor without the above knocking/detonation occuring.. This is due to the cooler combustion temperatures from the lowered compression..
BallHawk3
Jan 24, 2004 08:15 PM
Fatty_1775
Mar 7, 2003 02:31 PM
Cyber ITR
Feb 18, 2003 07:37 PM
98civicEX
Jul 31, 2002 07:16 PM
blazin
Nov 26, 2001 12:57 PM
