radiator
I have heard most pple recommend a del sol vtec radiator with the swap.
I am just curious, do pple mean the USDM del sol radiator.. that would be the SOHC del sol, rite? so any del-sol radiator is fine? I suppose, I just dont wanna get the wrong parts.
thanks
thanks
i think people mean the stock DOHC vtec del sol... i heard it was the same as the automatic 5th gen civics.
This is correct... both parts. It's the same width, is thicker, and drops right in with no additional work necessary.
The stock 5G civic automatic and manual only have a single core radiator. You will have to trust me on this because I have them.
The delsol makes 160HP so its logical that it MIGHT be enough to cool a 170HP GSR or a 200HP ITR.
The stock radiator will work but MIGHT overheat if you try to sustain WOT for long period of time.
#1) You need to study up on your Del Sol trivia...
#2) As was said earlier in this thread... DOHC VTEC Del Sol. - it doesn't matter which frickin' market it's from... it was sold in both.
#3) If you're not going to read for an answer, or at least verify whether what someone says is correct, then don't bother asking.
#4) yes, I am...
#4) yes, I am...
No. While you can use one from a JDM Honda Civic CR-X SiR, it is the same as a USDM Civic Del Sol VTEC. From reading your posts, it seems as if you don't know that there is such thing as a B16A-equipped Del Sol. Well, there is. It was offered from 94-97. So just get a USDM dual core Honda Civic Del Sol VTEC radiator. That is the official name of the model. You are confusing the Honda Civic Del Sol Si which is pretty much a Honda Civic Si/EX with the D16Z6 SOHC.
chill out dude.. while I appreciate pple's answers.. it was confusing that I didnt know DOHC del sol is sold in both market. So now that it's clear, I fully understand it...
and if you are so annoyed, dont bother to post. I dont need your attitude. and yes, I dont know enuf about Del Sol, that's why I asked. if you have a problem, **** off
use the stock radiator. alot of people use the stock one with no problems.
I did a gsr->into a del sol that was originally sohc 1.5
i go no radiator problems and I had the car for almost a year like this.
the soL that could
12
Mar 25, 2006 03:58 AM
