part # for del sol AC bracket
Old Apr 29, 2002 | 10:53 AM
KRiS1's Avatar
Default part # for del sol AC bracket
Does anyone have the part # for del sol AC bracket. What else do I need to retain my AC?
Old Apr 29, 2002 | 12:06 PM
CivicEx95's Avatar
Default Re: part # for del sol AC bracket (POS Hatchback)
I don't have the part number, cause I'm at work, but I will post it when I get home. I'll look at the box I got from Honda.
All you need to to retain AC is that bracket, and leave your Civic compressor hooked up, but unhook it from your old engine. It's sort of a bitch to get the engine out and new engine in while leaving everything hooked up to the AC, but we were able to do it, and don't have to worry about recharging it.
Old Apr 29, 2002 | 12:08 PM
KRiS1's Avatar
Default Re: part # for del sol AC bracket (CivicEx95)
cool, thanks
Old Apr 30, 2002 | 06:52 AM
decypha's Avatar
p/n 38930-P54-000
just make sure its the Del Sol Vtec..94-96..
it should have P54 stamped on the front..
also i had to get this stuff cuz i didnt have it..
parts off a 94 - up Integra
Idler bracket
Idle pulley
Idle pulley collar
Bearing cover
Special bolt and socket (Acura said this was *special* LOL)
AC belt (was a little loose, i got one size smaller)
good luck..let me know if you need p/n or a diagram..
Old Apr 30, 2002 | 07:52 AM
Kalokohan's Avatar
New User
What car?
What engine?
If you have a 92-95 civic with a B-series engine, you need a 94-95 del sol si a/c bracket that has a PR3 stamped on it if you want to use your a/c system.
If you have a 92-95 civic with a B-series engine, you need a 96-97 del sol si a/c bracket that has a P54 stamped on it if you want to use a 6th gen civic a/c system.
I could have the info switched around but you should be able to catch my drift.
My friend just tried to use a P54 bracket on his 93 hatch with a LS motor and the 92-95 civic compressor didn't completely line up.
Old May 2, 2002 | 12:29 PM
CivicEx95's Avatar
Default Re: part # for del sol AC bracket (Guardson3r3)
I just did a B18C1 into my 95 Civic, and I used the p/n 38930-P54-000 bracket and I was able to keep all my AC lines hooked up, and it bolted up no problem. I didn't disconnect anything so I didn't have to recharge the system.
Old May 2, 2002 | 01:25 PM
maxpsi's Avatar
listen to decypha and civicex95! it is the P54 AC mounting bracket that is needed out of the 94-96 del sol DOHC VTEC. The Del Sol has the B series motor but uses the Sanden compressor (stock civic cmp). I am 100% sure this is right cause i just had the B16A2 installed in my 2k civic ex 5spd. Dont think u have to covert all your AC over to the B series AC stuff. i bought my P54 AC mount for 150 dollars but ppl on this forum have gotten them for 100 dollars (the shop had to make a profit i guess i dont care my stock civic ex AC works just fine).
Old May 2, 2002 | 01:30 PM
Second2None's Avatar
Default Re: part # for del sol AC bracket (maxpsi)
Yep those guys are right. I just did a swap on my 97 ex coupe. I used the same ac bracket as they did. It was a 01 b18c engine. You might want to try hparts.com..Maybe a little cheaper. I got mine from honda and it was 130.00. pn 38930-p54-000. That was the year they had the dohc del sol.
ThE BiG RauL
Apr 14, 2006 10:14 PM
No-Gi
Sep 1, 2002 05:59 PM
Dorikamu
Jun 10, 2002 03:52 PM
