b20 specifics.
Old Apr 25, 2002 | 07:38 AM
Plan B's Avatar
Default b20 specifics.
what flywheel do i use when using a b20, all b-series flywheels the same bolt pattern? Thanks in advance.
Old Apr 25, 2002 | 07:39 AM
Spade's Avatar
Default Re: b20 specifics. (Plan B)
Take your pic.
Old Apr 25, 2002 | 07:43 AM
Plan B's Avatar
Default Re: b20 specifics. (Spade)
thanks bro
Old Apr 25, 2002 | 07:45 AM
Plan B's Avatar
another thing, the ls intake manifold is the same on all ls's right, so the 90 ls intake mani I have sitting around will work just fine, correct?
*edit* but using gray plug sensors, throttle body, etc. correct?
[Modified by Plan B, 11:45 AM 4/25/2002]
Old Apr 25, 2002 | 07:52 AM
Spade's Avatar
.....I cannot say for sure......the 93 and later engines I am not that knowledgable with the heads.
I am guessing yes though.
Old Apr 25, 2002 | 10:09 AM
Plan B's Avatar
i'm guessing yes also, if not, i'll just have to cut a hole in my hood to clear the giraffe intake.
Old Apr 25, 2002 | 03:47 PM
jdm_latino's Avatar
90-93 integra LS intake manifold will work on your b20
*DO NOT CUT A HOLE IN YOUR HOOD*
Old Apr 25, 2002 | 04:02 PM
Plan B's Avatar
Default Re: b20 specifics. (jdm_latino)
thanks, i was kidding about the hood. I do need to know something else though. Are the b20 heads and b18b heads the same. I know the blocks have different bore sizes so hence I was wondering if the combustion chamber is larger on the b20 heads? I know they use all the same parts for internals, but, ugh, if they're the same, i'm going to pick up this complete ls head and have it worked on while i'm out of town.
Old Apr 25, 2002 | 04:51 PM
owen_the_soyboy's Avatar
my bet is that the B20 head has th esame valvetrain pretty much as the LS head but of course th B20 head will have chambers that are bigger to fit the B20 bore.
Old Apr 25, 2002 | 04:57 PM
Plan B's Avatar
Default Re: b20 specifics. (owen_the_soyboy)
Yeah, I mean that was my guess. Although, it could be wrong, would the 3+mm bore size make that much of a difference, couldn't a machine shop increase the size just slightly so that it would be the same, or modify it to be perfect for my application, if so, wouldn't the ls head be better since it has more material to take off the combustion chamber to modify.
Old Apr 25, 2002 | 05:55 PM
customx_'s Avatar
New User
http://www.crvtec.com
Old Apr 25, 2002 | 09:33 PM
Suprdave's Avatar
The B20 uses a P75 Head Casting just like te B18B, and it doesnt have a 84mm Combustion Chamber...only an 81mm...
Suprdave
Old Apr 26, 2002 | 09:58 AM
Plan B's Avatar
Default Re: b20 specifics. (Suprdave)
so, the combustion chamber is smaller huh, crap, well thanks, i was about to buy a complete ls head today, I was going to keep it around and have it worked on while I drive on the other b20
egboostin6
Oct 30, 2007 12:18 PM
Dr.K
Oct 12, 2004 08:09 PM
ht834
21
Dec 4, 2003 07:14 PM
Arturbo
Jan 21, 2003 12:40 PM
Charlie Moua
May 16, 2002 08:54 PM
