What chasis for a b20?
Old Apr 26, 2002 | 11:34 AM
MaddMatt's Avatar
Default What chasis for a b20?
Checked crvtec already. What are the best chasis (easiest to swap into) for a b20 swap?
Old Apr 26, 2002 | 11:43 AM
b20b's Avatar
New User
Default Re: What chasis for a b20? (MaddMatt)
Easiest? It will bolt on to any car with a b series motor already in it. i.e. integra, civic
Old Apr 26, 2002 | 11:49 AM
MaddMatt's Avatar
Default Re: What chasis for a b20? (b20b)
OK, cool. I know it'll go into an EG, how about an EF? (sorry, not up on my Honda engine codes. What came in an EF?)
Old Apr 26, 2002 | 11:51 AM
Kalokohan's Avatar
New User
Put it into an EK hatch. Seen a clean black one on this board.
Old Apr 26, 2002 | 01:19 PM
fowler!'s Avatar
It'll basically go into an Civic from 86 all the way up to 00.
It'll bolt in with factory mounts into any civic from 92 to 00
You have to use aftermarket mount kits for anything older than 92.
An EF requires a mount kit. Hasport makes them.
btw, a SOHC motor came in an EF, not a DOHC as is a B20
Old Apr 26, 2002 | 02:40 PM
MaddMatt's Avatar
Default Re: What chasis for a b20? (fowler)
OK, that's the info I was looking for. Thanks. I assume the kit is not expensive or a big install deal for the EF, right?
In any event, when the time comes, I'll look for a 92+ first, and failing that, if I find a straight EF for a song, I'll definitely consider that.
Thanks again. I'm sure I'll be asking more questions soon.
Old Apr 26, 2002 | 05:43 PM
Pat McGroin's Avatar
you can put it into any chassiss you want as long as you have the money
Old Apr 30, 2002 | 07:52 PM
StorminMatt's Avatar
Easiest would be a 1992-2000 Civic or 1990-2001 Integra. But you can also swap this motor into a 1984-1991 Civic or 1986-1989 Integra. Best is a very subjective word, though. Are you talking best for performance? If so, go for a low trim 1992-1995 HB, low trim 1988-1989 (but NOT 1990-1991) HB, or any 1984-1987 Civic HB (the non-SI is alot lighter but mroe work is required).
quirarte626
May 1, 2009 03:21 AM
jdm Ef-9
Oct 29, 2007 08:53 AM
