Skunk 2 manifold??
Old Apr 27, 2002 | 09:56 AM
J.R.'s Avatar
Default Skunk 2 manifold??
I have a b18c1 in my 96 civic, all I have on it now is a intake and exhaust. Which in your opinion would give me more power, the skunk 2 intake manifold or port &polishing my stock manifold?
Old Apr 27, 2002 | 10:11 AM
eg6ajk's Avatar
Default Re: Skunk 2 manifold?? (96b18c1vic)
if you are going with larger cams, then go with skunk2 (top end will be improved), but if its for stocked cammed GSR with no other addons go with stock gsr
Old Apr 27, 2002 | 03:34 PM
june's Avatar
Default Re: Skunk 2 manifold?? (eg6ajk)
I love the skunk2 manifold. Its way better than the stock one. I can feel the difference
Old Apr 27, 2002 | 04:15 PM
hybrider's Avatar
Default Re: Skunk 2 manifold?? (civicefhatchback)
run some diff cams, reprog the ecu and get the skunk2 IM you`ll be very happy
Old Apr 27, 2002 | 06:54 PM
J.R.'s Avatar
Default Re: Skunk 2 manifold?? (hybrider93)
thanks guys for the replys
Old Apr 27, 2002 | 08:01 PM
Maximus's Avatar
I am thinking about getting a b16 head to compliment my b20 bottom end. How does the b16 intake manifold compare to the skunk2 one? Should I save my money and get something else or is the skunk2 one worth it. What about some other intake manifolds available on the market?
Old Apr 28, 2002 | 12:09 AM
EF_LSVtec's Avatar
Go with the Skunk2...no brainer...Type R specs for the B18C.
Old Apr 28, 2002 | 12:12 AM
EF_LSVtec's Avatar
Default Re: Skunk 2 manifold?? (Maximus)
Skunk2 has type R specs...If iweru, I'd get the CTR/ITR intake, it's slightly ported and bolts right on the B16
Old Apr 30, 2002 | 05:40 AM
HKxBlur's Avatar
Wouldn't have it any other way.. If you want ALOT of NOTICEABLE POWER, do as hybrider93 says.. If u want a little less torque and little more power, get the skunk2 mani.. Don't get me wrong tho, the manifold is fkn great, it's just that, intake/exhaust + skunk2 is not an 'optimal' next step for the $300.. If u do get it, every single thing that has to do with breathing will give u THAT MUCH more power.. (ie. cams, headwork, header, ecu reprog, etc).. But again, get cams/ecu first, and TRUST ME, you won't be disappointed with your newfound/cheap power..
njmad
Mar 18, 2010 06:23 PM
djteggy99
Feb 27, 2009 08:05 AM
95_red_dc
May 21, 2006 02:52 PM
Morhpeous
Aug 22, 2005 07:55 PM
i v o u s
Jan 27, 2005 03:31 PM
