Closed Loop?
Old May 2, 2002 | 10:57 AM
rschoener's Avatar
Default D16Z6 won't Idle. Closed Loop?
I have just Swapped A D16Z6 engine and P28 ECU into my 1989 Civic DX. I have rewired the whole thing. The Car will start and run but will not idle. If i disconnect the MAP sensor the car Runs great and idles at 1200 rpm. The engine light comes on and stays on. Any sugestions I have beeped out all the wires from the ECU to each sensor several times everyting is good.. Any ideas? I also have a lightened Flywheel Stock cut to about 12 pounds.
[Modified by rschoener, 8:05 PM 5/2/2002]
[Modified by rschoener, 5:37 AM 5/3/2002]
[Modified by rschoener, 5:38 AM 5/3/2002]
RiversideS13
25
Sep 22, 2022 07:03 AM
OwnsAnAcura
Dec 24, 2005 06:05 PM
rschoener
May 3, 2002 03:02 AM
b18c1-ek
Apr 16, 2002 03:03 PM
