in a ls vtec.. would you guys rather have b16a2 pistons or R pistons???
like topic says. R pistons or b16a2 pistons...
ummm if this info helps.. itr cams... itr head
or maybe just itr cams port polished b16a2 head
Re: in a ls vtec.. would you guys rather have b16a2 pistons or R pistons??? (CashedEG)
and yeild around a 12:1 cr. thats way too high for street. you may need octain booster.
Re: in a ls vtec.. would you guys rather have b16a2 pistons or R pistons??? (AzN_Flava)
with a b16a head and p30 pistons you can get into the 11.5 range with stock head and head gasket. thats pretty good for the street. ctr pistons require shaving the rods a bit while p30's drop in
Re: in a ls vtec.. would you guys rather have b16a2 pistons or R pistons??? (JCushing)
C/R (Compression Ratio) for the LS/VTEC
(B16a head on B18a/b block w/stock b18b rods) motor:
9.6:1 - P74 LS Pistons
10.0:1 - P72 GSR Pistons
10.8:1 - P73 US ITR Pistons
11.0:1 - P73 JDM ITR Pistons
11.5:1 - PR3 Pistons (1st Gen B16a)
11.7:1 - P30 Pistons (2nd Gen B16a)
12.4:1 - CTR Pistons
11.5:1 C/R is the "Safe" or target on 91+ oct street
pump gas.
So PR3 would actually be best.
pump gas.
