ZC into an automatic EF DX ... need some help for wiring ASAP!
New User
ok i am doing this swap for /with a friend in his EF ..
his car was automatic DX ..eheh
so we swapped the clutch and cables and stuff already..
but now i have to make the wiring for the ZC injectors ..
i was wondering if i could use the ZC engine wiring ..cause the injector resistor box plugs into on of the LH plugs...and i would try to use a USDM 91 SI civic ecu plugs from ecu to engine bay to plug the rest of the engine wiring into it
seems that there is only 1 additional plug on RH of the car from the engine..and the wires seems to be coming all from transmission information ( maybe back up light signal and stuff like that )
i know that we can find that plug on USDM SI so i would only use the SI wiring to the ecu..
but then i still need to wire inkectors so..
i would need to see an ZC/SI ECU MAPPING for wiring
like a picture with numbers of the wires and the function they serve..
like C-3 1st injector..or whatever it is ..
i already read all the stuff i've found on hybrid perf ..
thank you guys
(need to finish this tomorrow )
thank you guys
