please help!!! small problem with b16
Old Apr 26, 2002 | 03:10 PM
mkmoto's Avatar
Default please help!!! small problem with b16
I have a 95 civic 1.5 non-vtec (canadian), and trying to swap in a 2001 b16 (canadian). My problem is that I can't wire it up, almost nothing plugs in. I do have the new harness except for the piece that goes from the fuse-box to the radio etc. I would like to keep it obd1, but if I can't (for some reason) I'll settle for obd2. What should I do and how? Please explain in detail. THANX
Old Apr 26, 2002 | 06:40 PM
eg6ajk's Avatar
Default Re: please help!!! small problem with b16 (mkmoto)
one way is to, plug the Si harness to the shock tower points, anything left over is fine then get a obdI ecu
second way is, take your harness, add vtec, knock, reuse your injectors, and replug the distributor to 2 plugs or simply rewire it...and use obdI ecu ---the easiest way
Old May 2, 2002 | 09:21 AM
mkmoto's Avatar
Default Re: please help!!! small problem with b16 (eg6ajk)
thanks for the help, but i think i'm going to get this done by a shop.
majerst
Jan 22, 2010 10:23 AM
l2yanE
Nov 1, 2006 07:53 AM
deluzracerx
Jun 18, 2005 07:51 AM
bboylito
14
Nov 11, 2004 07:09 PM
