help me
Old Apr 24, 2002 | 10:03 PM
J.R.'s Avatar
Default help me
I just but a b18c1 in my car and I have noticed that ever since I had it put in, My radiator coolant level drops rapidly. I just filled it up last week and its already almost gone!!! So I check for leaks, no leaks, checked if my radiator was cracked and it was fine. Could my stock ex radiator be too small?? Is it not getting the job done? Please help any suggestions appreciated!!
Old Apr 25, 2002 | 05:11 AM
Jared's Avatar
Default Re: help me (96b18c1vic)
check your oil level and thickness.
Old Apr 25, 2002 | 06:56 AM
JD_B18CDX's Avatar
Its either.....
1. Going in your crank case
2. You did not bleed the cooling system right.
If its number one, you have a problem.
If its number 2 your ok. It will just keep doing it until all the air is out of the system.
Old Apr 25, 2002 | 10:51 AM
J.R.'s Avatar
Default Re: help me (johnd)
How would I check if its going in the crank case??
OverkillSD
18
Jul 23, 2009 01:46 PM
streetsmart
Sep 3, 2007 01:16 PM
P1mpSlap
Jun 18, 2003 08:15 AM
projectM
17
Feb 14, 2003 12:53 AM
FlipboiGSR
Jul 22, 2002 04:01 PM
