Which engine to swap into Del Sol??
Old Apr 27, 2002 | 09:26 AM
gshockbreaker's Avatar
Default Which engine to swap into Del Sol??
I'm thinking about buying a Honda Del Sol and swapping a engine into it. All you expert hybrids out there, which engine will fit and perform the best with a Del Sol. I'm thinking about spending about $4k on the engine
Old Apr 27, 2002 | 09:37 AM
Soku1kcivic's Avatar
Default Re: Which engine to swap into Del Sol?? (gshockbreaker)
Any B series with VTEC
Old Apr 27, 2002 | 10:21 AM
flat-blk-HB's Avatar
Default Re: Which engine to swap into Del Sol?? (Soku1kcivic)
well hell just buy yourself a 350 and convert it to back wheel drive!j/k!!
4K is a lot of money for a swap. I personally like my LS. But everyone seems to like the b16a so hey jump on the bandwagon and get one!j/k. LS/TURBO!!!!!!!!
Old Apr 27, 2002 | 10:51 AM
Default Re: Which engine to swap into Del Sol?? (89EF-BCUMBIE)
When I say $4k, I mean the cost of the engine and labor cost for swapping. Also, if I swap, will I loose AC and power steering?
Old Apr 27, 2002 | 11:04 AM
you should be able to retain both with a b series i whould think.but you might want to make sure. You and your friends could do the swap possiblity? could end up saving you a lot of money! But anyways your car is a Del sol.is it auto or 5-spd?
Old Apr 27, 2002 | 11:12 AM
Default Re: Which engine to swap into Del Sol?? (89-ED-bcumbie)
Didn't buy the car yet... Does it matter if its an auto or a 5spd... isn't a FULL swap including the transmission??
[Modified by gshockbreaker, 3:12 PM 4/27/2002]
Old Apr 27, 2002 | 12:13 PM
i expected you to do a FULL swap but i am asking becasue of the wiring harness and the clutch pedal you will have to add, the clutch fliud resivor,the hydro lines,etc.....that will cost you more if you are paying some one to do the swap for you!
Old Apr 27, 2002 | 12:28 PM
expand please... kinda confused...
Old Apr 27, 2002 | 12:52 PM
i said all that stuff if you get a auto-matic is what you will have to add.sorry i did not fully explain!
Old Apr 27, 2002 | 01:07 PM
khoalie's Avatar
hey ever heard of option2 delsol?
Old Apr 27, 2002 | 05:38 PM
Default Re: Which engine to swap into Del Sol?? (khoalie)
No.... what is that?
Old Apr 28, 2002 | 09:53 AM
yes i have.saw it in a magazine but i was talking about giving it some real V-8 POWER.hahahahaha J/K!!!
Old Apr 28, 2002 | 10:16 AM
khoalie's Avatar
yeah a while back i saw in a magazine, the option2 guys in japen had a RWD delsol.
they took stock motor out of the front and put a b18c r in the back.
i don't know what they did about the weight redistribution but they said it worked!
nickubus
Feb 29, 2024 12:30 PM
