Vtec Problem
Old Apr 23, 2002 | 07:21 PM
oneslowHB's Avatar
Default Vtec Problem
I just did a b16a swap in a 91 civic si. I am having a problem with the vtec. There's no power to the b5 pin (vtec pressure switch). The wiring has been check and is ok, but I don't know what it could be. Can anyone help?
Old Apr 24, 2002 | 12:53 AM
Kamin's Avatar
Default Re: Vtec Problem (oneslowHB)
ahh im not sure on this but that pin should only get power with vtec turns on
Old Apr 24, 2002 | 02:44 AM
rainforest's Avatar
Default Re: Vtec Problem (KAMiN)
pull the pin out of one of the un used pins i think b11 or b2 atleast in x's thats it. or go to a justk yard pull out the pins with connector then soildor the pin to the vtec wire and then you will be good.
swizz977
10
May 25, 2011 08:15 PM
Fireman.142
Aug 1, 2010 09:07 AM
delsol vti
Aug 27, 2007 04:09 AM
d16z6ef
11
Aug 3, 2007 06:36 AM
CRXHFB16
Jun 6, 2007 02:22 PM
