Frankenstein Motor Build-up Question
need a little help with some frankenstein bottom setups for a friend of mine:
1. B20B/Z block stock sleeves with 84.5mm aftermarket pistons
2. B18A/B block iron sleeves with 86mm aftermarket pistons
Either setup will have Eagle rods, new bearings, ARP head bolts, VTEC oil & water pumps, Z10 girdle ( and everything else needed to use the girdle )
The head will have somethine like a full P&P, Skunk2 Stage 2 cams, Portflow valve train, and ITR manifold.
The desired compression level will be in the 12:1 - 12.5:1 area or so...
Im just looking for outside feedback and ideas / opinions on these setups, thanks.
madking411
02-13-2011 03:19 PM
