JDM B16A swap into '94 Civic EX...what will be needed?
Old 04-24-2002, 08:25 PM
Yellow Dragon's Avatar
Default JDM B16A swap into '94 Civic EX...what will be needed?
Last year about this time, some friends and I did my swap ('94 GSR swap into '92 CX). It went fairly smooth. Just wondering what I will need to know beforing attempting this swap.
TIA
Old 04-24-2002, 08:55 PM
Kamin's Avatar
Default Re: JDM B16A swap into '94 Civic EX...what will be needed? (Todd C)
if you mean a second gen b16?
same thing as a gsr swap.
good luck
Old 04-24-2002, 09:06 PM
Soku1kcivic's Avatar
all the wiring is set just need a knock sensor and everything would fit in fine
Old 04-24-2002, 09:15 PM
Default Re: JDM B16A swap into '94 Civic EX...what will be needed? (Soku1kcivic)
Sounds great guys. Thanks!
I hear since it's a JDM engine...the wiring is on the wrong side. Is this true? I will only need to hook up the knock sensor? Cool.
Old 06-26-2002, 12:52 PM
New User
Ceeveek's Avatar
Default Re: JDM B16A swap into '94 Civic EX...what will be needed? (Yellow Dragon)
can the jdm wiring harness be used, or do I use my wiring harness..95 Civic ex
Old 06-27-2002, 05:24 AM
New User
Ceeveek's Avatar
Default Re: JDM B16A swap into '94 Civic EX...what will be needed? (Ceeveek)
ok.. I knowthe jdm cant be used, finally found it through a search. But what can I use, obviosly a Del Sol Vtec harness, can my harness be modified?
anyhone know where i can get a USDM harness?
JKov240
02-06-2007 11:46 AM
msinsky14
03-27-2006 05:53 PM
WreckedTeggie
02-28-2004 05:08 AM
fOmaNPu
11-27-2002 10:34 PM
fOmaNPu
09-16-2002 10:08 AM
Quick Reply: JDM B16A swap into '94 Civic EX...what will be needed?
