LS and B20 crank pullies the same....
Old Apr 25, 2002 | 06:56 AM
badCRX's Avatar
New User
Default LS and B20 crank pullies the same....
Just as the title implies. I'm thinking about getting the Unorthodox pulley for my B20, and they state the LS is the same. Are they correct or just talking out their ***?
Old Apr 25, 2002 | 08:20 AM
WAFFLES's Avatar
Default Re: LS and B20 crank pullies the same.... (badCRX)
I'm not for sure, however I know they are not the same as a vtec pulley.
Old Apr 25, 2002 | 08:46 AM
Sleeper's Avatar
You can use any Bseries pulley on any Bseries engine. But the stock B20 pulley is larger diameter, and heavier that the LS.
Old Apr 25, 2002 | 09:09 AM
badCRX's Avatar
New User
Default Re: LS and B20 crank pullies the same.... (Sleeper)
I'm more concerned about the correct timing marks in the correct location. I was ordering the race pulley if that helps.
Old Apr 25, 2002 | 09:32 AM
Spade's Avatar
Most racers (read Professional) are using the stock B18B crank pulley for it's awesome dampening capabilities.
Old Apr 25, 2002 | 09:41 AM
Sleeper's Avatar
Don't worry about the timing marks, thats why there is a key on the pulley end of the crank, so you can't mess it up. Stick with a stock honda piece, bearings don't like solid pulleys.
Old Apr 25, 2002 | 10:49 AM
badCRX's Avatar
New User
Default Re: LS and B20 crank pullies the same.... (Spade)
and who would these professional racers be? I'm not worried about bearing problems as this is a race motor that will be rebuilt every year or less. If both pullies were the same, would the pulley for the alternator be different sizes? I just got the one for the LS in from Unorthodox today the and the alternator size is different between the Unorth LS pulley and the stock B20 pulley. Once again this is the race one so that is the only thing to go by.
Also, are you talking about the keyway (I think that's what its called) that goes in the crank is what to base the timing off of? How do you do that?
Old Apr 25, 2002 | 11:53 PM
sek311's Avatar
if you think everyone is off topic why don't you ask Unorthodox????!
Old Apr 26, 2002 | 04:12 AM
badCRX's Avatar
New User
Default Re: LS and B20 crank pullies the same.... (sek311)
I have. Have you ever heard the phrase, "bullshitting a customer"?
Old Apr 26, 2002 | 04:26 AM
Sleeper's Avatar
Once installed, regardless of pulley choice, you can set timing like normal. Provided the timing marks are on it. Each different diameter pulley, has different timing marks to coincide. What I meant was you cant get it wrong with the key in the keyway. If its an underdrive pulley, its going to be larger than stock. If the B20 is larger its probably because the B20 crank pulley is larger and would overdrive the alt with a smaller size pulley on it.
Old Apr 26, 2002 | 08:24 AM
badCRX's Avatar
New User
Is there a way to confirm the timing marks are correctly marked or should I assume that Unorthodox did their job right?
hbboostman
Mar 25, 2016 04:38 AM
element1791
Jan 28, 2015 05:14 PM
civicjason
Feb 28, 2010 06:37 PM
CUL8RI1
Nov 30, 2007 12:19 AM
TheSwift1
May 3, 2004 09:04 PM
