SRS light is ON, any suggestions, using ctr srs & cluster
OK, About 2 weeks ago I installed my ctr srs steering wheel on my 99 dx hb.
No issues until the other day... I had noticed (2 weeks ago) that the s.w. looked a bit off center so I figured beginners error that it was off by a tooth and I should just pull it off and move it over a tooth.
Well it wasn't the tooth, it's the wheels out of wack... anyways when I re-installed the s.w. the srs light is now on.
I have been using my jdm ctr cluster for a while now and was also in when I installed the s.w. the 1st time.
~I have NOT YET checked to see if the srs connection is not on good, but I think the airbag would've exploded by now if that were the case.
Any suggestions / solutions?
Thanks
Thanks
Re: SRS light is ON, any suggestions, using ctr srs & cluster (B( * Y * )BIES)
WORD!
I found the old link with my answer.
Darn search feature sometimes doesn't work while I'm at work.
So nevermind!
So nevermind!
You took it off without disconnecting the battery.
sounds like you found the thread with the Helms fix.
If not get a Helms.....
Re: SRS light is ON, any suggestions, using ctr srs & cluster (owen_the_soyboy)
I did a search (on a diff pc at work) and found the link to the Do-It-Yourself and printed that out so i could fix it when i got home!
oh and I did have the battery disconnected
thanks
thanks
Cuda
08-25-2008 05:25 AM
sea plant
06-08-2008 02:04 AM
sk8shorty012
29
06-22-2007 02:01 PM
fastfour
07-17-2006 12:11 PM
