SWAP QUESTION;for a 95 CX Hatchback!!!
i have a 92-95 hb cx. i wanna do a swap! can i use a B16A Sir 2 Long Block - 92-00 (B16A Sir 2) Long Block170Hp 113Trq 10.4 Compression(JDM) 160Hp 111Trq 10.2 Compression(USDM)
would i be able to just bolt it right in or would i have to do, ecu,- mounts, and other jargen? Please help me cause i found this motor for a good price!!!Thank you so much to all that reply.
I U Guys!
I U Guys!
Re: SWAP QUESTION;for a 95 CX Hatchback!!! (flappy188)
You're gonna need a lot more than a long block. Long blocks don't have everything you're gonna need. You'll need axles, ecu, etc etc. Do a search.
If you're looking to do a swap, you should NOT be looking at longblocks, you should be looking for complete "swaps" or "drop-outs".
things a "longblock" doesn't have that you need:
axles
ecu
wiring harness
transmission
...etc...etc.
axles
ecu
wiring harness
transmission
...etc...etc.
.Thomas
02-11-2007 02:34 PM
p3s7
10-15-2003 10:45 AM
red civic standard
02-11-2002 10:04 AM
