Swap's running, heater doesn't work.
Old Apr 27, 2002 | 07:26 AM
JeffS's Avatar
Default Swap's running, heater doesn't work.
I took my car out for the first time yesterday. Everything's running great, but the heater doesn't work. I have no idea what to check...
help?
Old Apr 27, 2002 | 07:43 AM
JD_B18CDX's Avatar
Default Re: Swap's running, heater doesn't work. (JeffS)
1. Heater hose....make sure its connected.
2. Cable on the valve in the heater hose. If its not connected and remains close, cooland will not flow through heater core.
Old Apr 27, 2002 | 08:59 AM
JeffS's Avatar
Default Re: Swap's running, heater doesn't work. (johnd)
Just went back and looked at it. The heater cable had come out of the clip that holds it in place under the dash. When I moved the control the cable itself was moving instead of opening the valve.
I'll take it out later to make sure it works now....
Old Apr 30, 2002 | 07:49 PM
StorminMatt's Avatar
Also, make sure the cooling system is properly bled.
Old Apr 30, 2002 | 09:13 PM
SCsol's Avatar
Default Re: Swap's running, heater doesn't work. (StorminMatt)
open the bleader on the motor let it run till all the air bubbles stop coming out
mayfly
Dec 10, 2009 08:01 PM
724chris
Nov 19, 2009 12:11 AM
navin
Dec 16, 2007 10:04 PM
jdmomar
Oct 26, 2006 06:52 AM
4DRmafia
Jul 11, 2004 02:07 PM
