List of problems after swap
Old Apr 28, 2002 | 02:32 AM
CivicEx95's Avatar
Default List of problems after swap
Alright, put a GSR into my 95 EX. Still having a lot of problems with it. Here's a list of what I've noticed after one night of driving it.
- Heat doesn't work. Turn the fan to 4, nothing.
- Check engine light. Tried jumping the pins to read the code, light just stays solid.
- Car idles at 200 RPM all the time. When its real cold, it idled at like 500.
- Tach and speedo needle jumps. Shift lite also comes out and random times, usually during WOT.
- And the worst, when full throttle, car will accelerate just fine sometimes, but other times, it'll backfire and make the sound like you hit the rev limiter. Check engine light will turn off, then come back on. Happens any time during the RPM band.
If anybody has some suggestions on what to check, let me know. I'm sure we all know the feeling when something doesn't work on your car and you want it fixed. Thanks all.
Old Apr 28, 2002 | 07:19 AM
m0t0rhead's Avatar
Default Re: List of problems after swap (CivicEx95)
Describe what you used in this swap and the basic procedure you followed..
Old Apr 28, 2002 | 12:04 PM
CivicEx95's Avatar
Default Re: List of problems after swap (Escobar)
It was a JDM GSR going into my 95 EX. Pulled the old engine out, put the new one in. What other info would you like?
Old Apr 28, 2002 | 12:14 PM
B_CRUZ!'s Avatar
what harness are you using? your civic one or your the JDM one? what ecu? did you add the wires for the knock sensor?
Old Apr 28, 2002 | 12:20 PM
All Motor EG's Avatar
[QUOTE]Alright, put a GSR into my 95 EX. Still having a lot of problems with it. Here's a list of what I've noticed after one night of driving it.
Check engine light you just need to read the code then see what it is.
the low idle can be adjusted with a flat head screw driver on your throttle body. turn the screw counter clockwise to the idle you like.
tach is prolly your distributor. check the conections on the tach.
the heater im not to sure.
Old Apr 28, 2002 | 12:28 PM
JeffS's Avatar
Start with the CEL. If it's on, but not blinking when you jump it, I'm guessing you're not jumping it right.
Personally, I wouldn't even worry about anything else until you get that fixed. And I sure as hell wouldn't be running it WOT...
Old Apr 28, 2002 | 12:38 PM
hybrider's Avatar
Default Re: List of problems after swap (JeffS)
knock sensor? it could be a million things, check it the right way and take it from there as mentioned , good luck
Old Apr 28, 2002 | 01:41 PM
allmotorEG-SI's Avatar
Default Re: List of problems after swap (hybrider93)
Man your car is all f^#ked up... I'll give you $1000 for it.
Old Apr 28, 2002 | 10:43 PM
CivicEx95's Avatar
Default Re: List of problems after swap (All Motor EG)
UPDATE:
Alright, thanks everybody for the help. My car is almost done now.
- Heater didn't work because the fuse blew - doh!
- I wasnt jumping the check engine light correctly, did it right, got the codes
- As for the tach, I removed all the stupid wiring I had for neon lights and other ****, and rewired my shift light, just to make sure all the connections were good. Problem solved now.
- Idle was low because I had the connectors for the Intake Air Temperture and Idle Air Control reversed.
Still getting a code for the Intake Air Temperture. Check the helms manual and the colors are correct for that sensor. Going to need a multimeter to continue on the flow chart. Any other ideas?
94teggiels
Feb 11, 2009 10:35 AM
KrenzyRyan
33
Aug 1, 2007 03:08 PM
dirtycolombian
Jun 5, 2007 06:21 AM
jakscivic
May 14, 2005 01:49 PM
LsVtec98
Feb 17, 2005 04:09 AM
